I have a 20 yr. old, Heat-N-Glo SL32 direct vent. It has the Fenwal Direct Spark Ignition and it will not light.
![Heat-N-Glo (SL32) gas with DSI Won't Lite Heat-N-Glo (SL32) gas with DSI Won't Lite](https://www.hearth.com/talk/data/attachments/169/169981-c47ef9a6895fcf79e4d21d1cb792fc46.jpg)
In fact, it’s been this way for about 10 years and it’s time to fix it or replace it. I removed the logs and did a thorough cleaning including sanding the spark rod and ground on the igniter. I also cleaned ground wire & igniter wire contacts. I then checked continuity of the grounds and the spark igniter rod & wire. Everything is in order.
With the gas on, I flipped the rocker switch to ON and I hear a faint high-pitched whine (which I assume is the gas valve purging?) for about 4-5 sec. then it shuts off with no spark & no flame (lockout?). Repeated attempts fail also.
I do get a spark if I turn the rocker switch off after 1-2 seconds. So the module is capable of producing a spark.
I’ve also unhooked the spark igniter wire at the module then placed a grounded wire 3/16” from that connection and flipped the rocker switch on. Here again, I do get a spark when I switch off the rocker.
Questions: What is the normal spark pattern? Should the module/igniter be constantly sparking during the initial 4-5 secs. Or does it only spark once at the end of purge? Is this module dead or should I try some other test? Maybe it’s not getting gas and therefore shuts down because it does not sense a flame? I'm a novice with these systems.
![Heat-N-Glo (SL32) gas with DSI Won't Lite Heat-N-Glo (SL32) gas with DSI Won't Lite](https://www.hearth.com/talk/data/attachments/169/169979-ac856b2490999e6dfa9d021db1b6d865.jpg)
