Hello Hearthers,
I have a Heat N Glow Vienna 1 model that’s absolutely killing me. The system pilots and starts as intended but then abruptly shuts the gas solenoid valve off after 3-5 mins. I noticed the new pilot flame is less robust than the prior. Frustratingly, the pilot flow adjustment does nothing in either direction. I have disassembled and cleaned the stack- no obstructions and good outside air comes into the firebox. The main burner ignites after toggle “on” and has robust flame - almost too much. I’m thinking the thermal high cutoff switch is the culprit…but I’m not sure what changed. The summary symptom is the solenoid valve closes after 3-4 minutes consistently. I am tempted to bend the thermocouple closer to the pilot but don’t want to break it. It could be he thermocouple isn’t maintaining its signal.
What am I missing here? Is there a scenario where the thermal cutoff switch lowers its threshold? Replace the switch and see what happens? Thanks I’m advance!
