verne2 said:
joe thanks for the response! I have baseboard. With the info I have so far do you think the original system is oversized?
Just based upon your square footage, that system is oversized. You'd be hard pressed to find any residence eating that many btu's per square foot. Unless you have large windows looking over a lake, and you like keeping them open during winter windstorms, your boiler is plenty big.
For fun, measure your baseboards, and calculate how many btu's they can actually deliver to the house. Probably nowhere near as much ability to deliver heat as that boiler produces (of course, if they are overly long, that means cooler water temperatures will work, which means that each gallon of storage will heat for longer).
verne2 said:
so , forget about the price for a minute . would you install a 25 or 40 considering I have a 1000 gal tank?
If the heat loss is accurate, I think a 25 would be fine. What sort of burn times do you get with your 25, nofossil?
Pook said:
pretty hard to oversize an oil boiler, i think.
Actually, oversizing is one of the leading causes of inefficiency when it comes to oil boilers.
verne2 said:
The least amount of effort in loading the better. I wont be home during the day so a morning nite thing should work . If I can skip days all the better.do you guys think since I am on the line with size, a larger boiler with 1000 gal storage will give me longer time between burns?
The time between burns is a function of the storage volume, not the boiler. What the boiler size determines in that sort of system is the speed at which the storage can be recharged. Bigger boiler means faster recharge, but if it's too big, you will heat the storage to its full temperature before using up all the wood in the boiler. The theoretical goal is to have the boiler and storage matched such that you run out of wood just as the storage hits its peak temperature.
Additionally, to take advantage of the larger boiler, even if the wood loading were matched right, means a larger heat exchanger for the tank. The boiler cannot load the tank any faster than the heat exchanger can transfer heat, regardless of how much heat the boiler can produce. That issue can be eliminated if the storage is part of the boiler loop, so the heat exchanger is eliminated, but there are other issues with that sort of system which cause me not to recommend it - the biggest being that having the boiler separated from the storage means the storage tank can be shut down if it needs maintenance, without having to shut the boiler down (you just lose the convenience of storage in that rare case).
Biomass grower said:
Sorry, I just figured it out. 1 Therm = 100,000 btu's, so 150 therms/month = ~21000btu's/hr. So I think that means I'd need and EKO 25 right?
That means 25 would be plenty big, and then some.
Joe
