I recently used the heat loss calculator at [email protected] to calculate the heat loss on my 2,300 sq. ft. home. This is a pretty simple program and I'm curious as to how accurate it is. Based on a 70 F indoor temp. and 1 F outdoor temp (it only lets you calculate heat loss at 70 F indoor and 1 F outdoor) it says my heat loss is approx. 80,000 BTU/HR.
Does this figure sound reasonable? Does anyone else know of another (or a few) heat loss programs that I could run my calculations with to verify this figure?
Also, does anyone know what the required factor would be to calculate heatloss at a different outside temp (1 F is not the norm and thus as the outside temp. went higher the heat loss would go down)?
Finally, I plan to use my new EKO 40 and 1,000 gallon storage to heat my domestic hot water and 390 gallon hot tub. Does anyone know what the approx. heat demands are for these 2 items?
Thanks for your help
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
