Hey there. Have had this model for about 11 years now with no problems. Have used it almost every day for the last month or so, and suddenly it no longer lights at all. No spark when I flip the wall switch, no nothing. More details:
1. Fresh D-batteries do not seem to help. Have used these in a power outage once and they worked fine.
2. Tested voltage output by 3VAC transformer and voltage is solid.
3. Eliminated wall switch as a variable by manually touching wires together.
4. GFCI in bathroom right behind the fireplace was tripped, which I thought was suspicious at first, but doesn't seem related now due to previous items in this light. Could have tripped in relation to this problem or could have tripped months ago... we never use it.
I am thinking the problem is downstream from the transformer somewhere. Either the board or the ignition module itself.
Thoughts? Many thanks in advance...
