Moved into a circa 1780 center chimney salt box about a year ago. Came with a Vermont Castings Defiant 1945 installed in what we’re calling the “hearth room.” There is an additional open fireplace in the living room as well as another that was bricked over to accommodate the furnace. First winter was damn cold due to there being zero insulation in the house. This year is a sight better after qualifying for a 100% rebate on cellulose insulation. Never gonna be airtight, and that’s okay. Chalk it up to New England charm.
I try to not overfire my stove keeping it around 400-500F with decently long burns (still working on my timing and getting the most out of every load I put in the stove). With that, the VC definitely heats up the hearth room, but it seems to get trapped in there. The further away on the first floor, the colder it gets (as one would expect) but my sense is that I could be doing a much better job at distributing heat evenly. I’d prefer 65-68 degrees throughout rather than 75 in one room and 63 in another.
Additionally, the heat does not move upward to the second floor. This would be fine if it were just me because I’ll take any excuse to pile on wool blankets, but with a 7-month-old I’ve been told the upstairs needs to be warmed up some more. This one seems a puzzler to me because I always took as axiomatic that hot air rises, but you get halfway up the staircase and the temperature changes by 10 degrees F. You can actually stand with your feet in 75F and your head in 60F.
A little eco fan on the stove points toward the back door/mudorom (see schematic) and I’ve tried various iterations of using small floor fans directing cold air into the hearth room from adjacent rooms with minimal success (including down the stairs from the second floor, the “blueprint” doesn’t properly show that there’s 3 steps a small landing then a right angle before you head up the stairs).
I’d love to cut it up with folks on here about what they think might help, or if it’s a fool’s errand. Will happily answer any and all questions.
tl;dr: yet another Where do I point my fans? thread
![Heat getting trapped in one room Heat getting trapped in one room](https://www.hearth.com/talk/data/attachments/288/288611-4accc0f52c20784ff29e3e2592f0115b.jpg)
![Heat getting trapped in one room Heat getting trapped in one room](https://www.hearth.com/talk/data/attachments/288/288610-500192367f1c45b3369883d96a98b3ae.jpg)
