I am planning on buying a tarm solo plus 40 with roughly 1000 gallons of home-built storage. I am in the process of researching the heat exchanger and leaning towards using a long coil of copper (or maybe pex). I have a few questions:
- What are the minimum inside diameter and lengths needed?
- What type of copper should I use? I can get 10 ft of 1/2 hard copper tube at HD for 10.50. 100 ft would come to $105 which is not bad. Is it possible to get hard straight pipes and bend them into circles then solder a bunch of them together to form a large coil?
- How about soft copper coil? I am sure it would be easier to work with but costs a lot more - 20 feet of 5/8 OD is $57.82, so 100 feet would be more than twice as much as the hard tube.
- I noticed sparke is using pex and there was some discussion about heat conductivity. I looked up the numbers and polyethylene (not cross-linked , but that shouldn't matter to much) is about 0.5 W/mK. Copper is about 400 W/mK or about 800 times more than pex. This doesn't seem to match what sparke has observed (his system seems to work) so I am wondering if the material property doesn't matter so much as the water to material interface. When doing heat transfer analysis the interfaces are often more significant than the materials themselves. Anyway, what is the minimum amount of pex needed based on people's experience? Sparke, if you are there, you mentioned the performance was good getting up to 120 F. Were you able to get up to 180 as easily?
