Is it better to push the how water from the boiler through the heat exchanger or pull it through?
Looks like you need to change some of your fitting around for maximum efficancy.View attachment 192528
Top left is cold from house
Top right is cold to boiler
Bottom left is hot from house
Bottom right is hot from wood
Bottom pipe in background comes from the boiler hot, however it is pumping to the top right labelled cold to wood.
Essentially it's plumbed backwards?
Would this result in a loss of 20* from boiler to house?
Actually there isn't any counter flow.That is part of an efficiency problem,and mat be part of the difference temps.counter flow through the Hx, looks like you have that correct.
A simple digital thermometer from the hardware store with a sensor is adequate for temperature measurement. Wrap pipe insulation or a rag around the sensor for best accuracy.
Azel has a handy dual thermometer, battery powered and it reads out delta T. Amazon could have one to you tomorrow![]()
Here is a link to an inexpensive touchless infrared thermometer...you can probably get something locally if you look around. I use mine all the time.I don't have any way to measure those at the moment.
