I picked up my new HC Friday, unit #100...I think that is the easiest serial # I've ever had. It had a bit of a rough ride shipping (its a haul from La Guadeloupe Qc to beautiful downtown Boswell) but I was able to slide it gently off the trailer despite two badly busted up pallets...my sweetie cranked the come-along like a champ.
I read that another user had no issue hoisting it with the lifting eye...it does look a tad sketch... it only needs to come off the pallets then straight in to the shop so I should be good.
My ducting plan is pretty simple, I'm removing the electric forced air so I can use all the existing registers with new duct. House is 1300 ft main floor with 10' ceilings, Basement is pretty much wide open but there is no staircase, I have not committed to cold air return, but it would be fairly simple as well.
Question Re start offs on the plenum - the Drolet spec is pretty specific on using a minimum of 6 start offs, max 3 registers per run. My most efficient duct layout is 4 x 6" mains (112 in sq) with 9 x 4" (112 in sq) registers. Total end duct area will be equal to plenum start offs so is it critical I use 6 start offs? If so, then could I just do 2 short runs and damper the ends or do I need a minimum of 170 in sq of moving air?
John
Kootenay Lake Moose Pasture
![Heat Commander #100 Heat Commander #100](https://www.hearth.com/talk/data/attachments/275/275587-a5d6e73e3c5677a64622577722db8ee1.jpg)
John
