I just joined. I have an early model Mansfield stove and I noticed the 2 baffles above the fire tubes were distorted from over 15 years of use. Hearthstone and other suppliers wanted about $84 each for their steel replacement baffles ($168), so I found a website that supplies any size stainless steel you want. Stainless will not warp and last almost forever. The cost was also less, about $110 for 2-11"x13"x 1/4" plate stainless. This is a no brainer. I also ordered a new insulation blanket for $15 on Amazon, not the $40 one at Hearthstone. Be mindful that Manfield came in 3 models, so the double baffle system was only used on the original stove, then they switched to a single ceramic baffle. After my installation, which took an hour, I realized Hearthstone never placed a protection above the insulation, so the ashes and creosote dropping down from the 6" vent pipe falls directly on the unprotected insulation blanket. I added a 1/8" stainless cover on top of blanket here.
