My Hearthstone Shelburne is installed and last night we had our first burn. Here are some pics. I'm open to suggestions. My friend did most of the work and deserves the credit as I had no real clue and was learning as I went. He has an HVAC background and has done many many stove installs. He actually had to fab up some pieces as Lowes, Home Depot, TSC, didn't have what we needed. We did a slow burn at first with some papers to check draft, ect.... Then a couple of small pieces of wood, then after about an hour and a half, I put a couple of dry seasoned pieces in it and had the flue open about 65 - 70%. . THEN, I read in the directions that you can't do that or you will break the stove. You have to do several small burns and choke it off when the stove starts to get hot, ect........ SO, I panicked and choked it out allowing no O2. The stove was hot, but not hot enough to evaporate the water in the kettle on top. I woke up to one of the logs burnt up to ash and the other small log about 65% gone. The house smelled reminiscent of a morning after bonfire. I noticed creosote dripped down the pipe all the way to where the pipe goes into the stove. The attic had a bunch of creosote on the elbow.
I have some stuff to read and a LOT to learn. I guess with this stove I can't damper it down, I have to let er rip. There's no catalyst, but it is efficient, from what the manufacturer states. This is a learning curve. Here's some pics.
