Hearthstone Morgan door gasket?
IPLUMB
103
Does anybody know the Morgan door gasket size? Its been through 2 seasons should I change it? It seems fine but sometimes one corner of the glass gets dirty, So I may try the door seal if I can find the right size. Thanks
Try this link:
(broken link removed to http://www.hearthstonestoves.com/wood_stoves/morgan/technical_specs.shtml)
On the bottom of the page is a link to the owner's manual. That should tell you what you need to know.
You might want to check the glass gasket also.
Sean
I looked in the manual, the dealer CD, and the web, hearthstone states to call your dealerto order a kit, LAME. I guess i will have to call hearthstone to find out the size.
seaken said:
Try this link:
Sean
Nope. The manual does not tell you what sizes of gasket are used. Apparently, Hearthstone considers this privileged information only disseminated by an authorized dealer. Any HS dealers here?
I'm so used to the manuals having a section for maintenance instructions (VC, LOPI, etc.) that I assumed Hearthstone would have something similar. Sorry.
Sean
seaken said:
Try this link:
Sean
Thanks but all it says is to contact your dealer for a gasket kit :roll:
Its strange that they dont list it, open your door and look. Does it look unique? like a "tadpole" gasket, or is it round (which might look flat because of the door pressing against it) the window gasket is standard tape gasket. It might be the door gasket is a strage design and thats why they dont list it. Most all there other stoves its listed.
Its just normal round? I just did the dollar bill test and I can pull it out so I guess its time to replace. If you can help I would appreciate it very much. I just noticed that it does't look like they used any gasket cement from the factory? Doyou think thats right? Thanks Aaron
If its plain round gasket, then cut a sample and take it to your local hearth shop. Rhone has a hearthstone insert, maybe he can verify weither or not the gasket is glued. There stoves are. The new trend seems to be a channel that the gasket pushes into with no cement, but i doubt your insert is designed that way. It must be glued in some spots, otherwise it would fall out?
The gasket around my door fits in a track that's about 1 cm, held in place with gasket cement. I haven't had to replace mine, it's difficult to tell what it is because put a round rope into a square channel and use & abuse it for some time and the round rope will become squared so I don't know if it started out as 3/8" rope, 1/2" rope, or 5/8" rope.
If you (broken link removed to http://www.hearthstonestoves.com/documents/Clydesdale8490Manual.pdf) on pages 31 & 32 of the manual for the Clydesdale that gives you some good pictures of it. If using the page numbers Acrobat reader tells you, it's pages 32 & 33 for the Clydesdale. (broken link removed to http://www.rutland.com/gaskets/gaskets.htm#105) along with (broken link removed to http://www.rutland.com/gaskcemt/gaskcemt.htm#77). Places sell kits if you figure out what size rope it was originally, it doesn't look anything more than gasket rope pushed into the channel in my case. The morgans looks exactly like mine, judging by it's manual (broken link removed to http://www.hearthstonestoves.com/documents/Morgan8470Manual.pdf)
If someone here is a Hearthstone dealer I would appreciate this info. I no longer have a local Hearthtsone dealerThanks
rhone, i didnt forget about you, they didnt call me back yet, i will follow up tommorrow at work.
THANKS MoutainStoveGuy!!!! I just got back in town I really appreciate you doing that for me!! Aaron
