As far as wood stoves go, i'm somewhere within beginner to intermediate. I've got 2 hearthstones, a heritage (beautiful nice one) and the Morgan insert.
The heritage absolutely cranks out a tremendous amount of heat. I've done basic stuff like cleaning them, replacing the gaskets/cement, etc, and a little masonry work replacing the chimney cleanout.
However I can't seem to get my Morgan insert to really crank. I've only gotten it up to 350 degrees or so, so the heat output is definitely lacking. The baffle seems in place. I replaced the gasket around the main stove unit, but I see discoloration from what I think is cold air getting in the glass pane.
That's my last idea here is that the air coming in from around the glass (there is a secondary gasket esque fiber that surrounds the glass) is simply getting sucked upwards and out the chimney.
I've included a picture.
Anybody deal with this issue?
![Hearthstone Morgan 8470 Insert - Trouble Getting up to Temp Hearthstone Morgan 8470 Insert - Trouble Getting up to Temp](https://www.hearth.com/talk/data/attachments/273/273600-7ce758fae07d7111db0ca3afb158c8a9.jpg)
