I am looking for replacement options for a 1986/1987 non-catted Hearthstone III. It has served me well, but needs parts replaced that are no longer available. My reserach has led me to the Heartstone Heritage and Mansfield both of which will match the aesthetics closely to the existing stove, but about double/triple the BTU output all while staying within the confines of the existing fire pad.
The largest variables are the 20' high wall of 1980's double pane windows, tongue and groove ceiling/walls, and only R-19 ceiling and wall insulation. On cold days (single digits and negative), the house can barely keep 70' with the stove and electric baseboard heat on max. The room the stove is in is about 20x24x12' and is joined by two other rooms that are 10x24x12' above which is the master bedroom loft also with vaulted ceilings. When the stove is running the loft gets toasty with the loft doors open though the stove-level is never quite comfy unless the outside temperature is closer to freezing.
In the future, I plan to insulate the walls and roof. My first question is whether the Mansfield is overkill now. My second question is if the Mansfield is overkill if I majorly insulate the walls and roof, but still have that wall of older windows.
Any help would be greatly appreciated!
![Hearthstone III Replacement - Heritage or Mansfield Hearthstone III Replacement - Heritage or Mansfield](https://www.hearth.com/talk/data/attachments/277/277769-6ddcfd3a4ae833bf133d92800ec69d27.jpg)
