Hearthstone II Value?
Hatch
2
Castile
Hello, can anyone point me in the right direction on finding out the value of an older Hearthstone II soapstone stove. I think that is the correct model, the plate has a serial number but lists both the I & II models. My wife and I received it from a coworker years ago and never used it. We are getting our house ready to sell and we would like to get rid of it. I'm not sure if I should sell it just for parts or if someone can use it at all. I'm sure it would have to be gone through and checked, it has sat for many years out on our porch. Any input or help would be appreciated.
  • Hearthstone II Value?
Depending on the interior condition $300-500? A little steel wool to remove the rust and repaint of the metal with a stove paint could add $100 in value to the right person.
Did you
learn anything about this stove - im
Just now looking at a used one - and trying to figure out if I can move it
Did you
I had one of these. I moved it with an appliance dolly and got it up on my hearth using sawhorses and ratchet straps to lift it.
Check the condition of the baffle and the side/back plates inside. The baffle is still available for about $200. When I bought my stove, the baffle was burned out of it so I needed to get a new baffle right away. I replaced the metal plates inside of the stove the following year. I used 1/4" mild steel rather than buy the plates from Hearthstone. That turned out to be a mistake, but at the time I couldn't spend hundreds more on parts for the stove.
I guess I'm saying, it has internal metal parts that you should check out before buying it. If you think you are getting an attractive, old pre-EPA stove for a few hundred bucks you might have to spend another $500 on parts.
The thermostatic control worked halfway decent on mine. I thought that was a pretty fancy feature to have on such an old stove.
I ran it for a couple of years and then switched to an All Nighter. The All Nighter was a better stove, in my opinion. It wasn't as pretty, though.
Alternatively you could just get some fine steel wool and put a little elbow grease into it then use stove polish on it. I prefer it to paint.
