Hello, I have a hearthstone heritage soap stone wood stove that the cast iron side door frame (where the door latches) is worn so badly, that the door will not stay shut.
I tried to repair it with a high temp putty by filling in the worn area - it worked for a little while, until the stove heated up to a temp and melted the putty.
I ended up ordering a new door frame from the company I purchased the stove from. They told me that it would be a simple replacement, but after removing the four screws in each corner & the two bolts (top and bottom) of the frame, it is just as solidly in place as it was before. It appears that I might have to remove the top of the stove first, but I'm not sure how to get the soap stone off which looks like it is cemented to the top of the stove. Has anyone one ever replaced the side door frame and could you walk me through how to do it?
Thanks,
Cullen
Thanks,
Cullen
