Beam,
It that photo, the lower right most log is that on top of the doghouse? Can you load up on top of the doghouse? Did you always do a tunnel of love when reloading or just put it on the coal bed? Waiting to see what kind of deal my dealer offers me for the clyde. Just cannot decide between the Oslo or heritage. PH comes next if either of these two do not work out but it is major remodeling that the wife does not want me to do if it is not needed.
Looking at the EPA chart on Woodstocks website it shows the heritage's btu output better than the Oslo. Clyde heats our house fine. Just need to control draft better.
With the excellent side door you load ew and so can never build a tunnel of love. To get a tunnel of love Fed by the doghouse air you would need like 8" long splits loaded n\s.
Those jotul cast stoves look great.
I pushed almost 30 cords through my heritage before I sold it three years ago. The stove always did what it promised but I wouldn't buy another because after 30 cords, the hinges and latch had either failed or nearly failed. It is not a long life stove. Very pretty though and a solid heater.
So I never picked some arbitrary number like 300 degrees but I could restart without kindling 10 hours after a reload if I did a good job of filling the stove. If I recall correctly, it is rated for 9 hours. I only burned softwood and other low btu species, packed her full.
The heritage is just barely big enough to be an overnight heater. I would never get a non-cat stove smaller than the heritage if you want to use it for heating.
OK, I give up. What's a "tunnel of love" in a woodstove?
Pretty sure the "tunnel of love" is copyright protected by BrotherBart so he may have to give you the official description.![]()
Push the coals to the sides and leave a tunnel in front of the dog house so air can get to the back. Usually need it just for lighting the stove. Does anyone use the front door for reloading? Worth getting the ash pan? I know Highbeam does not like it, any other opinions? It would be nice to have the blower as backup but not sure it will fit.
I don't use the front door much at all for all the reasons Highbeam said. My Heritage came with the ashpan, but I just ignore it. I've never even opened it. I've read too many posts here over the years where people end up with an ashpan (not just Heritage stoves but others) that eventually gets stuck open a tiny crack by ash and led to a stove that burns way too fast. If you can get a blower put on later, I'd suggest waiting and seeing how the stove performs in your situation before shelling out the extra $$. Although I've never used one, I'm not convinced it's particularly useful with this stove in most situations.Push the coals to the sides and leave a tunnel in front of the dog house so air can get to the back. Usually need it just for lighting the stove. Does anyone use the front door for reloading? Worth getting the ash pan? I know Highbeam does not like it, any other opinions? It would be nice to have the blower as backup but not sure it will fit.
Nope, BeGreen holds the copyright on that one. Being PC I call it a "cave burn".
The ash absolutely does not have to fly all over the place and it won't if you shovel it out carefully. Start with a receptacle for it that's no deeper than the length of your shovel. Take out a shovel full of ash slowly and carefully, then slowly and gently put the shovel all the way into the bucket or can, and as Backwoods Savage used to say, instead of dumping the ashes out, carefully (and did I say slowly?) slide the shovel out from under the ashes. I get very little in the way of ashes around my stove by doing that.On the new model the ash pan is optional. After reading about the lousy design I was going to skip it. After shoveling the ash yesterday and seeing it flying all over the place I am reconsidering. Sounds like the same front door issue with the clyde.
This is what I use http://www.northlineexpress.com/black-and-brass-ash-bucket-ash-02-3086.htmlThanks for the info. Need to find a shallower pan. Usually not a problem if there are no coals mixed in but when it is hot. Dust ploom!
www.hearth.com/talk/threads/another-fire-starting-technique.139725/OK, I give up. What's a "tunnel of love" in a woodstove?
