Hi Folks,
Hope that everyone is having a good start to the burn season!
We purchased a new Heathstone Heritage Hybrid last year and are pretty much happy with it. We recently cleaned the chimney and needed to vacuum out the creosote pile from the back of the upper burn chamber behind the cats. Removing the pipes and baffles was no problem, but when vacuuming it out it pulled out parts of the ceramic insulation on top of the rear baffle (whoops, be careful where you vacuum
I did re-set the ceramic blanket back where it was and hope it will stay put when starting the stove with a high draft. 🤞
So here's the question: does anyone know what brand of ceramic blanket material is best to use in these stoves if we replace across the full width above the rear baffle across the lower burn chamber? And should the insulation blanket be glued down? If so, what kind of adhesive should be used? There does appear to be a big round adhesive applied from the manufacturer to the left and right of the bypass.
Thank you for your feedback!
--Phil
![Oops! :oops: :oops:](/talk/styles/default/xenforo/smileys/ohh.gif)
--Phil
