Hi all,
We bought a Green Mountain 60 back in September. It was the first *new* woodstove we'd ever purchased, so pretty exciting. Not for long....
Background: since 2000, when we moved into this house, we've been burning 2-3 cords per winter. We don't cut our own wood, but have it delivered seasoned and then we stack it and use it. It's always been a piece of cake, and a great way to keep our house warm. (We used to have an oil burner, now we have electric mini-splits to augment the woodstove.) Our first stove looked just like an old 70s Jotul, and our second stove was a 70s (maybe early 80s) Jotul and we burned and rarely had an issue. The Jotul had a crack on one side, so we needed a new stove. Enter the Hearthstone Green Mountain 60.
It's a pretty basic stove, which is what we wanted. Soapstone on the inside - nothing too fancy looking. But, ever since we started using it in November or so, it burns like crap. Hell to start a fire, particularly since any opening of the door while starting it releases a cloud of smoke. Once it's going it's okay, but it has been rare that we can get a fire going strong. As long as we place the wood in perfectly, with just the right amount of kindling, and start it with the door cracked and a fan blowing on the stove, we were able to get a fire going. Eventually, we could even close the door. Wow! Every time we've tried to use the catalytic converter, the fire has gone out. Sometimes just closing the door makes the fire go out. Our control of air flow on the stove is limited to a hole smaller than a dime at the bottom of the door, for which there's a latch. That thing is always open. (After the older stoves with the three air flow knobs on the front, this is quite a lack of control.)
So, we didn't blame the stove right away. We figured new stoves are more fussy, maybe our draft isn't as good as we thought. So we had a chimney liner installed. No insulation since the chimney is in the middle of the house, but a huge improvement for safety (the clay tiles were maybe 30 years old) and we hoped it would improve the draft. Nope. It's not worse, it's just not any better. Also, the chimney guys who installed the liner said the draw is fine, but said it would be better after getting the liner. Maybe it is.
The stove sits right in front of the chimney and the stovepipe goes straight up to a 90 degree angle, then directly into our newly lined chimney. The draft should be excellent. The chimney is kind of short at 17 feet, and the liner is open at the bottom so creosote can fall down into the cellar, where we'll clean it out of the chimney each year. (Just trying to provide as much information as possible.)
We've resorted to using bio bricks. Maybe the wood we bought this year is too wet. (And maybe the Jotul was more forgiving of wet wood. Chimney never had much, if any, creosote build-up over the years, by the way.) The bio bricks are better than wood for this stove - they are easier to start (not easy, but easier) and will burn well for hours. But we still can't open the stove door without getting smoked out of our house, nor can we adjust the bricks or add kindling. (I am aware that using bio bricks can void our warranty and considered not mentioning that we are using them. But at least they'll burn.)
I've read about other people having issues with this stove. Did we make a $3000 mistake? This stove is terrible. I can't believe how little control we have of airflow. It used to be fun to start a fire. Now we need gas masks. We do have the dealer coming out to look at the stove (for $289) in about a week to see if there's anything wrong with how it is set up. I'm concerned they won't find anything wrong (we didn't pay for installation when we bought the stove) and will say it's our problem, not theirs.
I'm very curious what opinions are from the experts. I think my ideal result would be that the dealer let's us trade this stove in and gives us an older used stove, not sure what kind. But I think that hope is probably naive. My wife has emailed Hearthstone and they put it all on the dealer.
Thanks for the thoughts!
Dan
Dan
