Hi there, new Hearthstone Clydesdale user here!
Had some issues last night with the stove running away more than expected and might need a replacement gasket but tightened up the door handle spring and we're doing better on the "dollar bill test." We noticed tonight though, that there's an open threaded port under the grill to the right, if looking at the stove. You can see flames through it. Is this a normal air inlet or should this be plugged? Tested it out with a bolt we have at home and it's a 5/16-18 which is the same as the set screws. I believe the draft port plug is in the center and plugged, as it should be, and is NOT this hole? I cannot find a part on the exploded view or any arrows pointing to it, although it's drawn in.
Thank you for any help!! Edited for more info.
