That would be a question for Hergom. Sometimes stove mfg. change design to have a more uniform control over a model line. Quad just dropped the Isle Royale which by any measure was a great stove. Replaced it with a different construction cast clad steel stove.The question you have to ask yourself is why they quit making the Bennington. There were a lot of complaints about the quality of it. They had it made someplace in Europe.
I'm not familiar with how the stove runs, but is it possible it is leaking air? Did you replace the gaskets and check the seams from inside with a flashlight to see if there are gaps that are visible from outside the stove?
My stove was burning through wood way too fast because I had a bit of an overactive draft; putting a key damper in the flue right above the stove's flue exit gave me that little bit of extra control so that I could slow the burn down to a more manageable rate of burn. Maybe you need to try this too?So the weather is great for woodstove burning , but I'm still having the same problem with the stove burning though the wood . It's not shutting down enough to have coals in the morning to start it back up . I replaced the side doors and the front door(s) gasket. The ashpan door looked good so I didn't bothers . Still not lasting through the night .
Does any one know where the primary air intake is ? I can see the pedal in the front , bottom right , is connected to a horizontal bar, then connects on each side to vertical bars , but then it's all interior so it's a mystery .
I have to get this stove going right .
Thanks for any help you can provide .
