How happy are you with the ash tray on your Hearthstone? Looking at getting a Phoenix. Seems some think the ash tray is more trouble than help.
The ashpan isn’t nearly as much trouble as all the cracked stones after a few years...
Most ashpans are a pain, a few are better than shoveling though.
So... the stones cracked from the heat - hadn't heard that before. how long did they last before cracking?The ashpan isn’t nearly as much trouble as all the cracked stones after a few years...
So... what would the problems be? it is nice looking but what problems will I encounter with the Phoenix or Heritage Hearthstone??Can I summarize to say that the ash pan would be the least of your problems.
I ran 30 cords through a hearthstone heritage I bought new in 2007. The ash pan was the size of a small book and I never used it. The ash pan door gasket was a liability with no reward. Some companies add a crappy ash pan just so they can say it has one and satisfy a prospective purchasers inquiry. Never mind the actual usefulness of the design.
The Phoenix is a really nice looking stove. One of their best looking IMO. Heck, most hearthstone stoves are quite pretty.
Hmm... have you ever had a stone stove? Oddly after going through several steel, several cast iron - I ended up with a Phoenix, then a Mansfield, then a Progress. Wonder why I kept getting stone stoves. My stone stove never goes cold as it retains heat for hours after the wood is gone. Always running from mid Nov to mid May so restarting means the stove is already warm.Stone stoves sort of suck in that you don’t get much heat until the stone is hot which takes forever and I believe people overcompensate for this by running it HOT!
Almost always the customer doesn’t know theirs is cracked either. You’ve gotta really look close and run your hands over the surface. It’s never the top, it’s lower back stones a most of the side stones. Maybe you didn’t keep yours long enough to experience this? Or just took it easy? I don’t think they all crack, just too often for my liking.Hmm... have you ever had a stone stove? Oddly after going through several steel, several cast iron - I ended up with a Phoenix, then a Mansfield, then a Progress. Wonder why I kept getting stone stoves. My stone stove never goes cold as it retains heat for hours after the wood is gone. Always running from mid Nov to mid May so restarting means the stove is already warm.
I had an ashpan on the Mansfield. Never used it once and never had a crack in any stove I've owned.
As we both found out, soapstone makes an excellent insulator! Not so good for a serious 24/7 heater. I prefer the heat to be released into my home, rather than up flue.My problems when running one for actual full time heat was durability and efficiency. The hinges wore out FAST and were not replaceable without a full stove rebuild to a pile of rocks. The thing would blow through wood to keep low emissions and high flue temps. Very nice fireview and clean glass due to this horrible efficiency. I dumped it on the used market and got a stove more suitable for actual full time use.
If you just want pretty and don’t burn it too often you will likely love a Phoenix. I had no cracks but I credit that to being a stove enthusiast and always being careful to run it below the manufacturer’s limits.
Prior stove was a Heritage. What I remember from that installation were the exceptionally high flue temps Highbeam was reporting. Lots of heat going up the chimney.Hmm... have you ever had a stone stove?
Same with my Mansfield.Prior stove was a Heritage. What I remember from that installation were the exceptionally high flue temps Highbeam was reporting. Lots of heat going up the chimney.
