I have decided on getting a new Hearthstone stove but am in a bit of a quandary trying to determine which model. I want to install it on my first floor Great Room which currently has a masonry fireplace with a small hearth. The fireplace measurements are 35w in the front tapering to 32w in the back, the initial opening is 30h inches in the front then going up to like 36h where the flap opens. The hearth in front of the fireplace is 16 deep and 73w. The stone on either side of the fireplace is 19w. I have provided a link below to some pictures of the fireplace, I can take more if anyone thinks it'd be useful.
The room that the stove would be in is about 670 sq ft, with the adjacent rooms being about 400, 125 of that being a 20ft tall foyer with a spiral staircase going upstairs. My priority would be to heat the downstairs (about 1000 sq ft combined) and get as much as I can upstairs (also 1000 sq ft). I have a whole house HVAC system which I've been told I could use to circulate the hot air around by turning on the fan. Is this accurate? The house is relatively new, built in 2003. It's pretty air-tight, all the windows were Low E double-pane high grade when installed. I was thinking about doing a cold-air intake option since my fireplace is already rigged for that (there is a 3inch wide hole on the left side of the fireplace).
I am currently considering the Heritage, Phoenix and Mansfield. Squeezing the Mansfield into the fireplace is going to be very difficult if even possible. I would need/want to put whatever stove I get partially inside the fireplace and the rest on the hearth with maybe 1/2 to spare from the edge. I'd then buy a temporary hearth to lay on the wood floor in front of the hearth (which is about 10 inches off the ground). I like the Heritage a lot but getting the side-door to open is going to be iffy, although I think it's doable. I would of course do a double wall pipe and rear heat shield with whatever I choose. My preference would be to use this as my primary source of heat, I live on a lot of acreage and have a hydraulic log-splitter, chainsaw, pickup and tons and tons of accessible wood. I'm kinda tired of dropping 2-3k a year on oil.
I think that's about it, any advice would be welcome and if you have questions for me just ask away.
Thanks.
Link to Pictures: (broken link removed to https://picasaweb.google.com/colorin/DropBox?authuser=0&feat=directlink)
Thanks.
