Hi,
This is my first post. I am in the process of a home renovation and installing a wood burning fireplace, zero clearance. The unit is the Napoleon High Country 5000. The unit is being placed on a raised hearth platform, picture of diagram attached. The hearth will be finished with thin brick veneer and a 1.75-2“ slab of bluestone. It calls for 5” of non-combustible material, the bluestone will be 2” but need ideas for building up the other 2.5-3”. I had two ideas and looking for some guidance.
Idea 1.0- put cement board on top of combustible wood frame, use traditional brick to create another 2.25”…. considering mortar for brick and slab It should make up most of remaining height.
idea 2.0 - frame the additional height with metal studs, I called a local supplier and pretty sure I can obtain 2.5” 18 gauge studs. Thinking I would secure the metal studs to the wood platform and make 3 rectangles.…one for the front(80”x 20”) and one for each side(10”x28”). I would the use cement board to cover sides and top so I can mortar the brick veneer and secure the bluestone.
I attached a few picture that may describe what’s going on better than I can explain. There is foundation support below the unit so weight is not really a concern. Any guidance would be appreciated.
Thank you
Tom
![Hearth structure - need help with non-combustible ideas Hearth structure - need help with non-combustible ideas](https://www.hearth.com/talk/data/attachments/290/290206-a6a4c91b3bffc38f1fbef56519504a33.jpg)
Thank you
Tom
![Hearth structure - need help with non-combustible ideas Hearth structure - need help with non-combustible ideas](https://www.hearth.com/talk/data/attachments/290/290203-138ea9f2e8eaa109fe60f46033d9dc16.jpg)
![Hearth structure - need help with non-combustible ideas Hearth structure - need help with non-combustible ideas](https://www.hearth.com/talk/data/attachments/290/290204-f7163a04274236a6ddb6baacf527b6fd.jpg)
