We have a raised hearth.is it ok to put the hearth pad on top of the carpet and butt the hearth pad up to the hearth???we have a f400 on the hearth and need to use a hearth extension.
Merry Christmas
Merry Christmas
BeGreen said:If it's an NPFA hearthpad, it's ok, but it should be captive so that a gap can not form between the pad and the hearth. You want a continuous ember barrier in front of the stove.
Edthedawg said:What's under that carpet? Hardwood you might want to refinish someday? or a more modern industrial-grade plywood subfloor that nobody cares about? If it's the latter, i'd say just plunk the extension pad down onto the carpet, butt it up to the face of the raised hearth, and pop a couple screws down in the corners of the pad w/ finish washers to hold it in place.
