Hello all, I am having a new Hearthstone Homestead stove installed on my old gas heater hearth (the flue is going to be relined) and I have been reading your posts on building an extension. My hearth is tile and is only deep enough to hold the stove and so I was going to either build up for my extension, or cut down to the subfloor like a few others did. At the time my focus was trying to match the old tile or otherwise make it look not too off. The old tile on the floor of the hearth was cracked in a few places and some ceramic was missing. I decided to just tear the old floor out so then at least the floor would match the extension. After starting on the tiles with a big hammer and chisel, I switched to an electric hammer chipper which made short work of the job, the only problem now is evidently the tile (1920s) was laid directly on a bed of mortar (I guess) and so the surface is not too smooth since it has taken on the surface of the bottom of the tiles which was 3/8" grooves. Plus the mortar is cracked in a couple of places (thus the cracked tiles, I suppose). The base is pretty thick, from what I can tell and I did not want to have to tear it out since my stove is due to be installed on the 30th of this month. I know this is a fire place forum and not a tile forum, but you all seem to have been down a few DIY roads and so I thought maybe someone would have a suggestion. Would a skim coat of mortar over the old base work do you think? Also, now I may have trouble making the extension match the level of the old hearth.... It seemed like a good idea at the time. I forgot to mention, the old hearth floor was level with my hardwood floor and it measures 5' x 19".
Oh, while I have your attention, I did not buy the steel surround which was going to cost another $250. Should I have one?
Thanks...
Thanks...
