Hearth extension underneath concrete slab repair
ErikNY
2
New York
The concrete slab under the brick hearth extension support is in bad shape. Slowly peeling and dropping in the basement. See picture. The hearth extension on the surface is not sagging and is in great shape. it's an old fireplace in an old house. Any advice on fixing it would be appreciated.
  • Hearth extension underneath concrete slab repair
If there is framing around this I think I would have a ladder frame welded up out of angle iron to hold it in place. Put up a sheet of cement board first as a barrier and then bolt the frame snug up to the cement board to hold it in place.
I can't say for sure without seeing it in person or at least much better pics. But generally if the support structure is failing that along with the hearth extension needs torn out and rebuilt.
No framing beside the wood beams supporting the floor. This is how it looks on the ceiling of the basement.
Can you post a wider picture of the underside including surrounding wood?
