Please correct anything I am about to say here...I think I have a grasp of what is needed for the hearth, but I would like some confirmation from the experts.
I will highlight my questions to make them easier to follow.
Hearth:
I am planning to purchase, either a Blaze King King or Lopi Liberty, over the summer (most likely the King). As far as I can determine, by reading their respective owners manuals, neither has a required R-value for the hearth...simply spark protection. So, I believe I can build the raised hearth frame out of 2x6's, then cover the wood frame with 3/4" plywood, cover that with a cement board of some kind, and cover the cement board with ceramic tile to finish it. This will raise the hearth to approximately 8" or so. If I am incorrect with any of this, please let me know.
I will certainly have to remove the carpet from this area, but should I remove the sub-floor as well? If so, this would open up the raised hearth cavity to the crawl space.
Will this construction be sufficient for a future replacement of the stove in 30 years? Again, correct me if I am wrong, but it seems more and more stove manufacturers are requiring less and less R-values from the hearth. So, in the distant future, is it safe to assume that most will only require spark protection...making this construction adequate for any future stove I may get. I realize no one can predict the future, but does this sound like a safe bet? I'm simply trying to plan ahead.
Surround:
I would like to cover the wall, behind the stove, for aesthetic reasons. I do plan to have the rear shield installed on the stove so I can reduce the clearance requirements to the rear wall.
What kind of wall prep will I need? i.e. - remove dry-wall, affix cement board to dry-wall, air cavity between dry-wall and cement board...
Thank you, in advance, for your guidance
Hearth:
Surround:
