I got this stove for free and believe there is still hope for it. It is dated 11/88 and this model was tested in 87. This stove has a tag on the back which I will let you read. The secondary burner is a metal box with about 20 holes on the front. I just added about 45 more 1/8 holes which you can see in the picture where the stove is upside down. The inlet if plenty big for secondary air but not sure how the air will be distributed. The air wash system is right over the top of the word stove and draws in are from the top . The slider does not move more than a 1.2 inch so you can't shut of the air totally. The primary air comes in over the top of the glass window. I am still working on it so any suggestions are welcome.
What do you think about putting an insulated blanket on top of the inside metal box? Will it be to hot for the metal? Or will it make things worse?
The width is 19 inches the depth is 16 inches and the height is 23 1/2 inches counting the legs. It is a small stove still trying to find info on it. I could not find model S131E . Not sure how much space it will heat.
![Haughs Wood Stove Haughs Wood Stove](https://www.hearth.com/talk/data/attachments/281/281018-f113fc52e2581e3c0a2db97f22522a82.jpg)
![Haughs Wood Stove Haughs Wood Stove](https://www.hearth.com/talk/data/attachments/281/281013-2f8bd577723c0ecf292d4d84169808e0.jpg)
![Haughs Wood Stove Haughs Wood Stove](https://www.hearth.com/talk/data/attachments/281/281014-257d7c0589f3530cf036b4d333733a30.jpg)
![Haughs Wood Stove Haughs Wood Stove](https://www.hearth.com/talk/data/attachments/281/281015-73dceba294e2755260b124855643bb45.jpg)
![Haughs Wood Stove Haughs Wood Stove](https://www.hearth.com/talk/data/attachments/281/281016-4b909f31cb43db8d09286333746a0f5c.jpg)
![Haughs Wood Stove Haughs Wood Stove](https://www.hearth.com/talk/data/attachments/281/281017-4c402568066c33099819cc512e5248a3.jpg)
