I'm not sure what to tell you, It could be a loose wire/ bad connection/ high resistance connection/ inside the stove or equally,it could be a component in the control computer or a bad connector inside the control computer.
If the stove is plugged into a surge protector, as mine is, try replacing the surge protector as a first and cheapest & easiest step.
If the stove is still under warrantee, contact the factory service and tell them about it so as to get the complaint on file before the warantee expires.
They may not be able to find the bad connection until it happens again, especially if it is an intermittant control computer electronic component.
![shade smirk >> >>](/talk/styles/default/xenforo/smileys/shade_smirk.gif)
BIT OF A RAMBLE ON BELOW , but should be interesting to the mechanically orented.
Sometimes, you can find a bad wire connection by pulling on the wires gently & if you are lucky, the burnt one will come apart in your hand, but I once had on that nearly drove me nuts, as the wire inside was bad but the insulation outside held it together and it seemed ok.
I finally found it on a desperation third check of all the wires concerned.
It was one of the power wires to a 3 speed whirlpool washer motor, so that the washer would not work on normal cycle, but worked fine on gentle & permanent press cycles
because those cycles used the low & medium speed motor windings being supplied by other good wires.
i cut the end of the wire off & soldered a new terminal on to it & plugged it back into the motor and it was fine.
A government bureaucrat probably wouldn't be interested in that.
An overpaid government bureaucrat certainly wouldn't be interested in that!
