Has anyone heard of Scandia model 160C?
lavetabelle
1
Colorado, USA
Any information would be appreciated! The plate on the back says it was made in Taiwan for Scandia Catalytic Corp. and tested in March, 1981, but as far as the internet is concerned, it seems like this stove doesn't exist. I did find the Scandia instruction manual on this site; it skips from model 150 to 180.
I've had it inspected and had the chimney cleaned. The technicians said it appears to be in good condition and should be safe to use. Since the photos were taken, I have removed the rust and paint spatters, put a little bit of liquid stove polish on it in hopes of preventing more rust, and cleaned the glass disc at the bottom of that little cylinder in the top. I'm a little worried about trying to use it because of the comments about Scandia stoves here, but the people who lived here before used it frequently. All thoughts and opinions are welcome!
  • [Hearth.com] Has anyone heard of Scandia model 160C?
If the inspector can be trusted it might be safe to use.
I question the inspector though, as it appears the 35" clearance from the side is not met - that is to combustibles though, so if there is no stud or drywall behind the brick it might be okay.
Looks like a copy of the Jotul 121. The castings on some of these stove could be iffy, but with care some people have had them in service for years. Shine a bright light inside and look outside for light leaks. Check the air control to make sure it provides reasonable closure when all the way closed. Also make sure the baffle and side burn plates are in good shape.
Here's the manual for the 121.
