Seeing references to kiln dried cord wood popping up, makes me wonder why one would not use a vacuum to dry wood instead ? If one lowers the ambient pressure, the water in the wood will boil off without requiring heat. One needs a chamber in which to load the wood and draw the vacuum and of course a vacuum pump (one can use salvaged refrigerator motors which do not draw to much power to begin with). Boiling off water at low presure requires far less energy than at normal pressures, so it seems like it would be more efficient ?
Is the reason behind using heat that a certain amount of the yield (dried wood) is used as a ready energy source in the kiln drying process ?
