I want to know witch stove is better the p61 or p68. I have read that the p68 is noisy and likes to eat pellets?
Delta-T said:$2800 is a good price on a slightly used P68, you get the full warranty? If so, get the 68. Even if you don't "need" the extra BTU output, you get a bigger hopper, the fancy mirrored glass and the door latch is nicer on the 68. Running on low they have the same appetite and output, but you can turn the 68 up higher than the 61. Good luck.
rona said:It is always easier to turn the stove down when you get too hot then it is to wish for more heat when the stove is on the high sprocket.
jtakeman said:rona said:It is always easier to turn the stove down when you get too hot then it is to wish for more heat when the stove is on the high sprocket.
"X2" Been there done that, Brrrrrr!
