So the temp finally dropped down to a point where I could feel good about running a full out test of my used Harman P61-A stove. First off, my set up is as follows
Installed in semi-finished basement
Vented to single flue masonry chimney
Only "appliance" on that flue
Vented using standard black chimney pipe as per dealer recommendation (3 foot rise then into the chimney)
Before installing I thoroughly cleaned the stove in accordance with the manul and cleaning guide.
Burning premium grade New England hardwood pellets
Problems are as follows <sigh>
1. Ignitor failed to start the stove after several tries. I got it to work on one brief test run 2 months agao, but it appeared to "struggle" and barely lit the stove. Not a huge deal, I figure i'll be replacing it for 60 bucks. Stove started fine manually with stove gel as per the guide.
2. The stove has been running on feed rate 3, stove temp high mode, 80 degrees for aboyut an hour and it seems that the distribution blower has not yet come on. The stove is throwing good heat, but there must be an issue of some sort.
A quick google search seemed to suggest that there might be an issue with the ESB probe?
The light indicates that the blower is getting power.
Any thoughts?
My thought is that you should think twice about buying a pellet stove out of some guy's garage in July (with no way to really run a thorough test)
Any thoughts?
