Greetings -
Please excuse the incoherency of this post - I am a brand new Harmon Advance owner, and my ignorance will no doubt be evident.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
My old QuadraFire Nova gave up the ghost last year, and I replaced it with a Harmon Advance. Winter was late arriving this year, and as of today we have used the new stove regularly for maybe two months.
The stove has developed an intermittent rattle during operation that is sometimes so loud it echoes through the house. From reading the manual and posts on this board, it looks like the problem may be due to fine build-up behind the ash box, causing that box to not seat properly so the two metal panels on the sides rattle.
So yesterday I took the whole thing apart and cleaned everything in sight, making sure to get the area around the back of the ash container as clean as possible.
This solved the problem for most of yesterday, but then the rattle started up again, after the stove had been running for a while, and nothing had been opened or removed. This is not the feeder grinding when a pellet gets crossed in that mechanism - we have that as well, and have identified it.
This is a constant (when it happens) loud rattle that happens when the distribution fan is running. We have not noticed the rattle when this fan is off, even if a fire is burning. It sounds like two pieces of metal vibrating against each other. Like a chunk of steel in the metal bed of an old pickup going down a washboard road. Currently this is intermittent - it won't rattle at all for a while, then, with a constant fire and no opening of the stove or anything, it will start up and rattle like the dickens for a while ('while' is hours in each case), then stop, again with no activity such as opening the door or anything.
When I had the thing apart yesterday I looked at pieces and nothing was obviously bent or warped, and all the gaskets look to be in good condition.
I guess my main question for now is, how 'picky' is this stove in terms of re-assembly after cleaning? I am mechanically inclined, but as mentioned still ignorant regarding this stove. Is it most likely that I just didn't get something exactly back in the right place and that is causing this rattle? Or could something be warped and that is causing it? Or ???
Any thoughts or ideas from you folks that know this stove better will be most appreciated. If I have been unclear about something (likely, I reckon...
), please let me know and I'll do my best to provide more information.
Thanks in advance...
