I bought a new Harmon Advance pellet stove in February of 06. It works fine but has an annoying rattle that comes from the sheet metal baffles whenever it is taken apart for a thorough cleaning. (About every ton). After it gets a few hours on it the fly ash stops the noise. The stove is located om a ceramic pad on the wood floor of a framed house with a crawl space. Last year I got into the crawl space and shored up the area to no avail. All you have to do is walk by the stove and rattle, rattle, rattle! I last cleaned it this Spring, (that's June here in Oregon). The only thing louder than the rattle was my wife hollering about it so I pulled it apart again to wait till a fire is needed. The 4 baffles in question appear to be 10 gage sheet metal and fit in front of the accordion heat exchanger and behind a cast iron false brick back wall. Tried shimming them in with bits of asbestos but the back wall must slide down about 2 inches when inserting and that doesn't work.
Does any one else have this problem? Is there a fix? I was thinking about a high temperature duct tape or something to seal them in? The local dealer says if I come up with anything he wants to know what it is!
Thanks
Thanks
