We just cleaned our stove and now it keeps feeding pellets but won't ignite. I tried unplugging, resetting, emptying front tray, and even manual lighting (no gel). I can't get a fire started and I can't get the pellet feed to stop!
Stilllife1 said:The Accentra/Advance (I think my XXV needs it too) has a modification where 5 holes get drilled into the burn pot near the auger. This is to help prevent the carbon build-up. Only the newer stoves come from the dealer with the mod. My dealer told me that mine should have it since i bought it in May. It does not. I also get smoke in my hopper when the pellets are low. There is a mod for that as well. Mine does not have it. Apperently Harman has only issued that mod for the Accentra and Advance, but I know mine needs it. I'll be talking to my dealer about it soon.
Dougsey said:Lousy, Have you seen any connection between OAK and gummy slide plate?
Lousyweather said:accurate...what HV14 said. I dont agree with the 15 minute changeout.....an insert takes between 30 and 45 minutes, but freestanders are easier. Also, while you have the multimeter out, check the resistance of the igniter. The "old series" igniters, often faulty, had lower resistances, 40-44 ohms, while the newer series (good) igniters have 46-49 ohms. If the igniter has failed, HV14 is right....no continuity....and often the igniter will be slightly bent. Please note though, the igniter has nothing to do with a gummy slide plate.
2Sweaters said:Lousyweather said:accurate...what HV14 said. I dont agree with the 15 minute changeout.....an insert takes between 30 and 45 minutes, but freestanders are easier. Also, while you have the multimeter out, check the resistance of the igniter. The "old series" igniters, often faulty, had lower resistances, 40-44 ohms, while the newer series (good) igniters have 46-49 ohms. If the igniter has failed, HV14 is right....no continuity....and often the igniter will be slightly bent. Please note though, the igniter has nothing to do with a gummy slide plate.
My Harman insert won't start...it's been running fine for a few yrs, usually only not starting when it's overdue for ash cleanout. Cleaned out ashbin, etc. Did thorough cleaning of burnpot. Rapped on clean burnpot with tool several times to shake any loose ash off of igniter and cleaned it out of box thru doorway, but am not sure if igniter's actually impacted with ash, etc. Burnpot holes were all open; had read about them getting clogged, so I tried to clear them with a toothpick from above...all seemed wide open, and when toothpick eventually slipped and fell down hole, it fell right thru burnpot out thru burnpot cleanout doorway into ash bin. Restarted, but after 15min, burnpot still COLD.
So I'd like to check if igniter's shot or not getting power, as suggested:
1. Do I have to remove insert from fireplace to chk w/multimeter whether igniter's getting juice? I haven't pulled insert (had dealer do preventive maint every year+ or so...was at work, so didn't see it pulled) Fireplace flush w/floor, so no rails needed?
2. Where are the 2 points to touch w/meter leads? and how do you access them? (thru doorway? around back after pulling insert?)
3. Canned air seems like a good idea...will get some...am assuming you spray it down thru several holes in burnpot?
4. Reaching fingers up thru doorway, can feel igniter teeth/plates(?) between two curved metal plates(?) front one of which seems to have a little play -- not sure correct position of it or whether/how to tighten. When people talk about cleaning igniter, do they mean reaching up thru doorway and brushing those teeth with some sort of brush?
Would like to DIY if possible to save $, but happy w/dealer.
Thanks
