We have a Harmen P43 Pellet Stove that is relentlessly smoking inside. I will note that we got it for free and it was in good condition but sooty when we picked it up. The combustion air smell of smoke fills quickly once we turn on the stove. Husfriend has been in HVAC for 30 years and we can't seem to figure out why the stove is throwing smoke through the warm air holes from the top of the stove. He's replaced ALL exhaust venting, high temp silicone on all connections, cleaned the freaking stove endlessly and we're using a high quality pellet. Door gasket is in excellent condition. There is no signs of smoke when he uses his laser in the dark. Not a single puff of smoke coming from the guts of the stove in the rear of the stove. Just a ton of smoke coming out of the hot air vents. He did notice the that there is exhaust smell coming out of the hole from the exhaust fan shaft. Should the hole be positive or negative pressure? What would cause the smoke to be present in the house but not anywhere in the rear of the stove or in the venting? It seems as thought that the exhaust is coming out of the exhaust fan shaft hole and being sucked into the circulation fan. Is there supposed to be a gasket in that area? Any help is much appreciated!
