Harmen accentra 2
Ernch2
1
Connecticut
Stove runs blowers in test mode, put new anger motor in tested it first works fine still can't get pellets to load into burn pot,also manually turned anger an it turns any ideas??
Empty the hopper and check the fines box to make sure the slider plate is moving back and forth. That lets the pellets drop into the auger feed.
Vacuum switch? Is the feed light going on and off? If yes, is the auger turning?
