Hi everyone~~I have a Harman xxv made in may 2009. I'm using 3 inch vent pipe with the vent pipe going two feet straight out the wall, then going up 5 feet. All joints are sealed. I also have 3 inch pipe bringing in clean air from the outside. My house is a well insulated 1800 sq ft cape cod style home. The stove is cleaned every two days. I use LG premium softwood pellets made from black spruce and grey pine. BTU/lb is 7765, moisture content is 6.97%, ash level is 0.38%. THe stove runs great, but i want peak efficiency while using the least amount of pellets and i have other questions you may be able to answer. How big of a fuel use difference is there if you run it at 75 degrees as opposed to 65 degrees? Don't you want a minimum feed rate from the feed adjuster so your using minimum fuel and maximum speed from your distribution blower so you blow as much hot air into the room as possible while maintaining the temp setting you want, and how is this accomplished. Should you turn your igniter switch to auto to get the stove going then flip it to manual so it goes to low burn when you don't need a lot of heat so your igniter won't have to keep going on and off all day or will this use significantly more fuel? I heard their may be a problem with igniters not lasting or is that due to not cleaning the igniter area under the burn pot enough or being to rough with the igniter when cleaning? When their is ash buildup at the top end of the burn pot does that cut down on efficiency? I run my distribution blower at about 65%, with the temp dial on 62 degrees and the feed adjuster on 4. If i turn the distribution blower to 100% to blow more hot air into the room will that require me to turn up the feed rate, and why wouldn't you want the blower at 100%, isn't hot air being wasted up the vent if it's not at it's max setting? I ran it at the 65%-62 degrees- feed on 4 setting last year for the first season and after the season was over i pulled the distribution blower and feeder body and cleaned the stove and pipes and everything was not that dirty. How do you decide weather to use room temp mode or stove temp mode? Do you really need to do a low draft voltage adjustment with a draft meter if your bringing in outside air? I did the installation myself and didn't do that process. Will it make a big difference if i do? What is the purpose of the holes on the burn pot surface that i keep clean? Does the stove self adjust the feed rate for any reason or is it not capable of that? If your using room temp mode and the stove goes to low burn because it's reached the temp you've set it to and the feeder is still feeding at the same rate, isn't that just wasting all the heat up the flue till it calls for more heat again? And what is the pattern of air feeding the fire circulated throughout the stove as it comes in from the outside? Sorry for so many questions, the stove is running well but i just want to use the stove in the most efficient manner. Any help on these questions will be most appreciated. Thank you~~Merry Christmas and Happy New Year.
