Had been thinking about adding an inline switch to the pellet feed motor power for the times that a normal shutdown doesn't seem to be working and a cleaning of the ESP probe doesn't help. For me a removal and cleaning of the exhaust vent piping usually is the fix to get the shutdown to work properly, but not something I have the desire to do during a period when I need/want to run the stove, thus this is the 'Band-Aid' until I can remove and clean the vent. I had been using the pellet hopper lid with its feed motor switch to kill the stove previously, but I think having it open for a period of time alters the draft of the stove and I had concerns about the possibility of the remaining fire working back to the hopper.
The wiring for the feed motor is easily accessible and connected with quick connect type spade connectors, so it's easy to break the connection and add a switch in series with the motor. (I did change out the quick connect spades on the motor power leads as the spades I had didn't fit what Harman had used). The cable from the switch is routed through vent slots at the bottom of the stove and avoided drilling any holes. The small utility box with the switch is fastened to the stove with heavy duty Velcro, is out of sight from the front of the stove, and removal is easy if needed. Labeled on top to show 'ON' and 'OFF'. If I get ambitious I'll paint the utility box black.
![Harman XXV Pellet Feed Switch for Shutdown Fail Harman XXV Pellet Feed Switch for Shutdown Fail](/talk/proxy.php?image=https%3A%2F%2Fi.imgur.com%2F1jWeJTQ.jpeg&hash=a0df30754856d88ee9bc81433cf197ed)
