- Oct 16, 2012
- 107
My XXV is 9 years old and this has been going on for the last 7 years at least. I run the stove on the continuous mode, not with the room temp mode so it does'nt keep shutting off an relighting. Switches are on "stove temp" and ignitor is on "automatic"
When I shut the stove down to clean it, it hardly ever lights up with the ignitor and when it does, many times the unburnt pellets will overflow outta the burn bin then sometimes it will start but I usually have to use firestarter gel because after 15 minutes or whatever the stove has blinking lights and it shuts down, When I use the firestarter gel (imperial from Lowes) it is usually a hassle getting the flame to take hold. It is usually a VERY lazy flame with no apparent draft to feed the fire and it usually goes out untill I keep squirting the gel into the burn bin repeatedly to get the pellets going again apparently due to lack of oxygen getting fed to the pit. Finally it will take hold and start burning on one side while not burning on the opposite side until the fire spreads. I have cleaned the ESB probe, replaced the probe and this has no effect on starting. I have replaced the ignitor twice with no better startup. I even replaced the control board and that did'nt help. The seal on the hopper seems to be in good shape as it alters the flame bigtime when I open the hopper.
I asked my local Harman dealer service man if I may need a new rope gasket on the door and he said that has nothing to do with the fire getting ignited. It's kinda weird tho that everytime I clean my stove or open and shut the door that immediately after that the ignitor won't work and it's hard to start with gel. If I have the door closed for hours while running the stove, then shut it down and DO NOT open the door it will lotsa times start back up using the ignitor.
Seems to me that the burning fire may put soot around the door seal and if I don't open the door the the seal stays intact but if I open the door then it breaks the seal. I presented that question to my Harman tech and as I said earlier, He said that has nothing to do with ignition.
I'm a bit frustrated on this matter as I'm going thru a lot of gel firestarter not to mention the hassle.
Even tho the rope seal looks good and is clean as I vacumn it gently everytime I clean the stove it seems to me that's the cause but was told different by the professional Harman tech.
I'm getting a bit fed up with this EXPENSIVE pretty stove that does NOT work correctly, I even have problems with the dist. fan as my last one only lasted 13 months, is a REAL BEARCAT to remove and harder to install and costs over $350 a pop
I'm about ready to sell this lemon and go back to a wood stove or another brand of pellet stove, I've been fighting this thing for years now....pert near ever since brand new and I've got a friend who bought a cheap other brand and he has had ZERO problems with it so that REALLY bumbs me out with my lovely beautiful XXV, Sure is purdy but don't work worth a darn
I've replaced EVERYTHING at least once except for the auger motor
These pics are me trying to light it with gel for the fourth time till it finally got some draft going and lit
