- Oct 16, 2012
- 108
I've had my XXV about 10 years and the last few years it's been really hard to start.
I bought a new ignitor, new computer brain, new exhaust probe, cleaned everything possible and nothing helps. No flashing blinking codes either
Usually if it's dirty and the door has'nt been opened for a few days of running then it lights up a lot easier after being shut down. Usually about 8-12 minutes it takes. Every once in awhile it goes too long spilling fresh pellets over the side of burnpot and it shuts down after 15 min I think.
If I clean the stove then it pretty much never starts on it's own right after a good cleaning (my thinking is that I broke the seal on the door) and i gotta use gel lighter and start it manually. And I gotta use a lot of gel as the fire is a lazy flame and does not get the draft needed to have the flame take off. Once it catches on (sometimes 10 minutes OR MORE of screwin with it) and warms a bit then the flame catches on with a good draft and takes off and will run for days after that just perfect, until the next shutdown.
My thinking is that when I open the door I break a "seal" of ash that is helping seal the door. My stove is 10 years old and never had the door rope replaced. I did the paper test and it seemed to be pretty tight but hard telling there.
I called my local Harman "tech" at the fireplace shop and explained it to him and he said no way does a bad door seal affect the starting of the stove
I know thats his job and gots to be smarter than me in that area but I'm still thinking I'm right but don't wanna replace the rope if that ain't the problem
Any hints or tips - - opinions greatly appreciated
Thanks!
Thanks!
