We have an early model XXV we bought in 2007. Other than replacing an igniter 3 years ago it has worked great. I was getting a banging noise a couple of weeks ago and it turned out the auger bearing had gone south. While removing the old auger I found that the receiver nuts for the auger retainer fell out. They were not welded in place as I understand they now are. The one on the right side was easy to retrieve but the one on the left was not. The holes for the nuts are slightly oversized and I was afraid while reinstalling the auger retainer I'd push them back out. To avoid this I put a bit of plumbers putty on the interior flanges of the nut and used clothespins to hold the nuts in place. The bolts are long enough to hand start them then remove the clothes pins to complete tightening. If I ever need to do this again I'll remember to just break the bolts loose and pull them toward me to keep the receiver nuts in place.
![Harman XXV Auger Replacement Harman XXV Auger Replacement](https://www.hearth.com/talk/data/attachments/306/306240-39e182f0de1e7607b2316447dabf20ef.jpg)
