I picked up a Harman TL200 exception on craigslist for $150. I saw that there was some damage, but I figured if it was unsalvagable I could break even by parting out the blower and brass door.
So here is the damage. I'm unfamiliar with the stove and with woodstoves in general, so I might not be seeing it all. Advice on what to look for would be appreciated.
1. When I look down the 6 inch pipe, I see a damaged ceramic thing. It has a hole in it. I assume that this is the afterburner.
2. The afterburner weldment (see front pics) is melted/damaged in the middle.
3. Below the afterburner weldment are two bolt holes with nothing attached. I assume that this is where the glass originally was?
4. The damper seems OK, but there is maybe a 1/8 to 1/4 inch gap in the top when its completely closed. Is this OK?
The guy who sold it to me said that he used it and that it burned hot. I can see that, since the hole in the afterburner leads directly to the weldment, so there is an open airway even with the damper completely closed. Is this safe?
What is the best way to make this stove completely safe? This will be backup heat for me, so efficiency is a secondary concern. Is it worth buying all new parts for?
Thanks
![Harman TL200 exception damage Harman TL200 exception damage](https://www.hearth.com/talk/data/attachments/147/147796-cc0322e4e6396d46543adadb05e887fb.jpg)
Thanks
![Harman TL200 exception damage Harman TL200 exception damage](https://www.hearth.com/talk/data/attachments/147/147799-3cbabee88576060732ef7c6f26d7ce31.jpg)
![Harman TL200 exception damage Harman TL200 exception damage](https://www.hearth.com/talk/data/attachments/147/147794-14f2afeec68b5da1178b9a4044102999.jpg)
![Harman TL200 exception damage Harman TL200 exception damage](https://www.hearth.com/talk/data/attachments/147/147795-0f875ac319b8ae889dee2880e2f3cb1b.jpg)
