The other day I noticed what appeared to be an unusually high number of sparks flying out of the burnpot of my Harman advance. I didn't think too much of it at the time.
The next day, I came home and the stove had shutdown (I forgot to load pellets before I left). It wasn't too cold in the house yet, so I decided to take this opportunity to give the burnpot a good scrape. 5 minutes later, I loaded the pellets and fired the stove back up.
10 minutes later, no ignition. This has never happened to me and my stove... usually lights up in 4-6 minutes. I let it go for another 10 minutes or so, but no luck. So, I take the pellets out of the burnpot (which are hot, but not black in any areas), roll out the shop vac and give the burnpot a more thorough cleaning.
2nd try and the stove ignites... though took longer than usual (10 minutes or so).
Yesterday was in the mid-50s. So I decided to give the stove an even more intensive cleaning. Burnpot and fly, hopper, ash pan, glass... pretty much everything but the back of the stove and the vent pipe.
Start it back up, and again... no ignition (15 minutes or so). So, since I didn't know what else to do, I emptied the burn pot of pellets, and tried again. This time it ignited.
So, I'm at a bit of a loss. I've looked at the board read stuff about vent leaks (Is there an easy way to test for leaks?), low/high airflow (can I adjust air flow on the Advance?), lazy flames (how do I know if I have a lazy flame... or is it one of those things where you'd know if you saw it) etc... but I figured I'd see if anyone has experienced anything similar, or if anything in my story rings any bells.
I'm still seeing plenty of sparks, but now I'm not sure if it's in my head since I had the ignition problem... I don't really remember seeing as many sparks before my ignition issue, but who knows.
Thanks in advance!
Thanks in advance!
