Held at Northern Lights in Farmington
He covered maintenance & cleaning items and answered many questions.
Key items that I picked up on:
1) He noted that if the best part of a Pine tree and the best part of an Oak tree were used to make pellets, there would be little difference in performance.
He did give a slight advantage to softwood for ash. The main differences are introduced by the manufacturer.
2) The combustion fan speed should be set to middle position. Ours is maxed out which he said can lower the burn pot temp.
3) The "Fines" catch box needs to be cleaned every 1-2 yrs. I plan to check every year.
4) The new style ignitors have 15 fins vs 13 on older ones.
5) Clean the ESP probe gently with water, alcohol and even Gin. I'll drink the Gin instead!
6) If the ESP probe gets bent even a little, it is most probably bad. Thin wire inside is not supposed to touch the sides.
7) He said that running the stove in "Room Temp" mode is the most efficient mode.
8) Suggested spraying a light coat of WD-40 to the inside for Summer months to prevent rust. Spraying burn pot area OK also.
9) Stove shutdowns: Have noticed that the stove actually feeds pellets while shutting down. (Turning temp down)
This is normal and is an attempt to prevent fire making its' way past the auger and into the hopper. GOOD IDEA!!
A local Access TV Station filmed this and may be able to offer copies.
I will get the info if anyone is interested.
