we have a dicussion going that says Harman Room temp mode will feed itself for 22 secs if on feedrate of 2 NO MATTER WHAT THE TEMP SENSOR IS READING
Im saying the stove will feed itself whatever it needs to reach that given temperature even if it has to feed itself for more than 22 secs and once it reaches set temp it will feed for less than 22 secs...the feedrate in ROOM TEMP MODE is overriden by the control board
here is the only proof of my argument
heres HARMANS ANSWER
Room Temperature Mode
Most consumers use the stove in the Room Temperature Mode because it is the easiest and most efficient method of keeping the room at a given temperature. In the Room Temperature Mode, the Room Sensing Probe constantly monitors room temperature. As the weather changes outside and your home needs varying amounts of heat to be at a desired temperature, the stove will automatically increase size and heat output of the fire so that a constant even temperature is maintained. If the weather warms up and no heat is required the stove will gradually shut down. When the house cools down the stove will automatically bring the room temperature to the precise temperature you desire
is there something I'm not seeing?
