Harman PF120 issue with 4 blinks using thermostat
Rayterio666
39
Dieppe, NB
I have the furnace for 2 yrs now and always been on an Honeywell T5 thermostat and worked like a charm, but for the last 3 days, my status light blinks 4 times and then the stove does not shutoff, but goes on until it runs out of pellets... did not change anything, any ideas what is going on?
Tks
From Harman:
4 Blinks: Can occur only in the Automatic Mode and
indicates the Wall Control has failed or is not installed. If a
Wall control is then installed the status light will automatically
reset.(Note) only after the unit has warmed up.
Sounds like your t-stat is on it's way out, or there's a connection problem...
Forgive a noob question, but could this also result from t-stat batteries running down? Inquiring minds want to know!
Trust me guys, there is no stupide question!!!!
My T5 is powered via a12 volts transformer, same type as a doorbell transformer.
I tried another non-WiFi thermostat I was using before this one with no issues when I changed it, same results, I even tried Harman’s analog thermostat that came with the furnace and still the same issue.... see pic.
Now I am guessing either the control board ( which is kinda expensive to replace) or the ESP probe...
Any thoughts, idea will help me!!!
Tks a million!!!
  • Harman PF120 issue with 4 blinks using thermostat
