This is the 3rd winter that I am going into now....had two great years with a slight learning curve. Have a new problem that I am hoping that great people on here might be able to help me out with. On an irregular basis (but maybe 1-2x/week) I have been getting a 5 blink error light. I did a complete cleaning of the boiler (thought I had burned less than a ton since the start of the season), and also cleaned the vent pipe. Also, my igniter recently burned out, which I replaced and am still getting the error light. Thought the problem was solved, but I was wrong.
The area under the burnpot and igniter are clean and the holes in burnpot are all unobstructed.
another idea i had was dip switch settings....how are people's set? the first three of mine are off, on, off and I also tried off, off, on and still have the problem. switched them back to the original setting, since those worked just fine thru the previous winters.......
Anyone have any other suggestions to try?? Troubleshooting advice?? Thanks in advance for any suggestions...you guys are usually spot-on with your advice....Happy Heating!
